I couldn't find gdiplus.dll in the help folder for 2006.
It was bundled with 2005 but not 2006. Therefore I managed to copy it across from another machine.
Also, 2006 still seems slow wrt 2004.
The tuned bandbass filter example runs really slow when I tune the capacitors. It runs really fast (fluid) on 2004. (tuned bandpass.wsx)
In 2005.11 you had to manually copy the file into the bin directory.
With 2006.04, if you are running Win2K, the installer should put the DLL in the bin directory for you.
