GENESYS runs in a single window like most standard Windows MDI (multiple document interface) applications.
Starting with version 2005.11 you can stretch the window across multiple monitors or just have GENESYS run in the alternate. You can also place synthesis property dialogs and the status window in the alternate monitor. GENESYS versions prior to 2005 do not support multiple monitors.
Mark
