Hi there,
i am running Genesys 2007.08
I am trying to get a plot of the Noise floor from a 2 port system (simple amplifier and filter) by using the NMEAS measurement available from the measurement wizard.
I get a Measurement ‘NMEAS’ not found warning when I run the sim and a No data in the plot.
I have tried adding a variable in the Linear_Data and using NMEAS in a formular to fill a table of the noise floors but similar results. I have included the test workspace to see if you can see where things are going wrong.
do i need to embed the NMEAS in a formular somewhere to get an array i can then plot? i though
Kind regards
Dan
Kind regards
Dan
