Skip navigationLog in to create and rate content, and to follow, bookmark, and share content with other members. I am getting this error on any design I am trying to simulate with momentum. Running "as administrator" on windows 7 x64. Genesys 2008.07, MomentumGx MomEngine 8.0.281Would appreciate any help on this.
Simulation started on : Thu Feb 17 22:19:44 2011
Simulation Mode: RF
Substrate valid
Mesh generation at 3GHz.
Mesh generation finished
ABORT, physutl_fastmath_getConfig: unable to determine the configuration for blaslapack
--- ERROR ---------------------------------------------------------------------
File for proj.cti €N‡ could not be opened!
Check : - existence;
- access permissions!
Could not create dataset ./dataset.ds
Can you please download latest Geneys 2010.05 version and install SP1 on it and see if the Momentum simulation issue exit or not?
Sridhar
