I tried using Genesys 2010.05 again at work today for some simple designs (handful of parts) and I hit the usual netlist bugs.
However, I usually find that saving/shutting down genesys and restarting clears the worst of the problems.
However, I think this particular wsx deserves an award
This one fails to fix itself and has lots of problems.
See how many blatant bugs you can find in this wsx file. On my PC (22" monitor) I can spot several problems and anomalies.
See attached wsx
See attached wsx
I did add a third port but then genesys wouldn't let me delete it.
I started this wsx from scratch and pasted in about three lumped parts from another wsx. Obviously these parts had a few hidden friends...
Can I ask when the next release is due?
Hopefully it will be more stable. This software sends me crazy every time I use it. I can't believe I am the only person hitting these issues.
Maybe you should use me as a beta tester.
