I have a multiport network, and I want to export the data set to a Touchstone file. Selecting Export and choosing S-parameter files (i.e. here s6p) I do get a file but this do not adhere to a true Touchstone formatted file.
According to the help files this file should be
Fq S11 S12 S13 S14
S15 S16
S21 S22 S23 S24
S25 S26
etc.
What I get is something like this:
Fq S11 S12 S13 S14
S15 S16
S21 S22
S23 S24 S25 S26
etc.
Am I doing something wrong here??
Fq S11 S12 S13 S14
S15 S16
S21 S22 S23 S24
S25 S26
etc.
Fq S11 S12 S13 S14
S15 S16
S21 S22
S23 S24 S25 S26
etc.
Now import to a new workspace with a simple 3-port network, using the data I just saved. Now the S12 and S13 shows positive numbers i.e. gain. Something has reversed!
I made sure port 1 always set as input and 2,3 set as outputs.
Update:
Looking at the specifications for an input file this is not what a Touchstone file format specifies. AND it does not conform to the export format. I.e. the program cannot read the file that it has previously exported (in a correct way).
I suggest that if you want to keep the formats for export and import (legacy reasons) why not add a Touchstone tick box allowing to use the industry standard? This goes for both import and export!
