Eagleware 2004-07
Windows XP SP2
When I run eagleware I get an error that reads
Unhandled exception
An unexpected error(GPF or otherwise) occurred.
GENESYS crash protection has attempted to catch the problem.
All simulations have been disabled.
SAVE YOUR WORKSPACES to *NEW* FILES AND
EXIT GENESYS IMMEDIATLY
See attached
I can click OK a couple of times and then goto tools>options and re enable simulations and they work. When I go to close the work space, I get the same error come up.
I have tried un installing Genesys and re installing it.
I have downloaded and installed the HASP USB key driver.
The key is plugged in and the codes are entered.
I have tried switching Norton OFF and Microsoft anti spyware OFF and the windows XP fire wall OFF and all off at the same time.
Fresh out of ideas. Can you help.
Thanks, Frank Thomson
[file]error message unhandled exception.doc[/file]
Windows XP SP2
Unhandled exception
See attached
I'll open a support case for you and someone
will be in touch shortly to pursue....
