Most of my work uses slab line designs.
I have had problems that I have worked around but now I am at a standstill. HELP
The combline design uses an air dielectric but M-Filter insists I use a substrate from the library none of which use air. If I try to add a new substrate I Get an READ ONLY error message. I enter a new substrate with each task.
Now comes 2005. I am designing a 900 to 906 MHz BP filter with reasonable values and the dimentions in the equation window are insane. The graph seems to produce a reasonable response but spacings llike 0.0023. I have set the default units to mils.
Also I can not find what substrate is being used.
Sorry for the headache.
Jack Kouzoujian
Jack Kouzoujian
I am going to move this post to the Product Questions forum. I'm sure they will want a copy of your workspace so they can see what is going on. So you might go ahead and post your workspace file in the thread. They will also want to know what version of GENESYS and Windows you are using.
The support team moderates the Product Questions forum. If you post your "How to Use" product question there it gets logged in, the time taken to answer your question is monitored and if there is a bug it gets registered in the product development database.
Clear skies and high Q
