Is it possible in G2005 to import non S parameter matrix data for manipulation within the program. For instance, would it be possible to upload measured Output power vs input power data as a function of frequency (resulting in a 3 by y matrix, y is the frequency number) for comparision within G2005 with simulated non linear model results? In the documentation I have seen, only S parameter data may be uploaded. It would be very powerful to be able to use the matrix processing capabilities of Genesys with externally (to the program) generated data.
It may be possible to do this; if you would like me to take a look at your data points and suggest a course of action, please email them to peter_karasev@agilent.com
