I would like to use the nonlinear voltage controlled current source in a model. The help available on this source lists the parameters as 1=exp,2=poly,3=pade,4=spline C Coefficients.
When I insert the NLVCCS into the schematic, and pull up the parameters, the only parameter visible in the parameters window is a resistance. Is this parameter actually meant to be the transconductance (transresistance?) and given by Vin/Iout?
What significance (if any) are the parameters identified with exp,poly,pade, and spline. And what significance is the C?
