In MomGX Property window/mesh tab, TL mesh automatic option is available in 2008.07. But I think it doesn't take any effect on meshing because ADS Mom doesn't have this "automatic" option.
I just report it feeling a concern that it might be wrong implementation.
Just reporting.
Umekawa
Just reporting.
Umekawa
ADS has this option, but it's UI is different. It switches to automatic mode, it TL mesh = 0.
The same way may be used in Genesys UI, setting it = 0, but using radio-buttin option is more clear, and allows to keep manual mesh settings to switch back to manual mode.
By the way Momentum Engine has a lot of other control options, which have no ADS UI at all, but available only by setting them in Momentum config files.
Sergey
