We always need to turn the io lines in a non tapped combline to avoid short circuits with coupled lines.
Turning io lines is tedious and I never know where to locate it once turned.
Moreover, If we set parameters, turn the io lines, optimize and change the input parameters again, I think (not sure) the new topology puts the io lines in the same axis than coupled lines.
Couldn't you change this io lines start topology in genesys ?
Marc
Marc
