Following are some references for getting started with GENESYS:
Overview:
Eagleware provides a wide assortment of training material to help
the new user getting started with Genesys as well as the experienced
user who wants to expound on their Genesys knowledge. These resources
include:
* online videos
* design examples
* user guides
* application notes
* An interactive forum to post questions to EaglewareStaff and
other Genesys users.
Where to begin:
Begin by starting the Genesys software and getting familiarized with
the Genesys environment. When you start the software there is a handy
utility screen where you can open a previously saved workspace or
create a new synthesis. You can also close this screen and start
with a blank Genesys workspace.
For a great overview of the Genesys workspace, see the video #1025 at:
http://www.eagleware.com/apps/ByNumber.htm#VideoApps
(Go to the link above, then scroll down the page and view video #1025)
Here is a quick list and description of things that you will see in
the Genesys environment:
* In the center of the screen, you will see a blank schematic where
you can add elements to create a design.
* On the top of the screen you will see some menus. The top most menu
is the 'Main Genesys Menu'. Below that you will see toolbars. One of
these toolbars has buttons called 'Lumped', 'Linear', 'NonLinear',
etc... When you click these buttons a floating window will appear
where you can select a part to put into the schematic.
* On the right-side of the screen is a part selector. Here you can also
search for a part and select parts to add to the schematic. You can
close the part selector by clicking the 'X' in the top right corner
of the selector window.
* On the left-side of the screen are two windows seperated by a divider.
The top one is the tune window, which is used for tuning part values
and the bottom one is a folder tree that contains analyses,
designs, graphs, optimizations, etc. To add and item click the "add
item" button just above the folder tree.
There are a number of resources available to
help you get started with Genesys:
* Become familiarized with the Genesys help. This is a very valuable tool
It contains a complete set of Genesys Manuals and has two books
written by Randy Rhea about Oscillator and Filter Design. To use the Help,
click Main Menu Help/Contents. Here you can browse through help by
tobic. In there you will see a Getting started topic. Read through the
getting started information in the help. If you want to search for a
particular thing in help but are unsure where it is located, click search
and type the topic.
* Genesys contains a wide assortment of examples. If you need an example
of a component that you want to create, then open the examples. You can
get there by clicking Main Menu File/Open Example and choosing one of the
examples to open.
* After you have read through these resources, go back to the web and begin
watching the other videos for additional help.
* There are also Genesys Training Classes available from many U.S. and
world-wide locations. Contact your Eagleware Sales person for locations
and times of these sessions.
This information will help you to come up to speed using Genesys
in a very short time. If you have specific questions after using
the material referenced above, feel free to email support@eagleware.com
Overview:
include:
* online videos
* design examples
* user guides
* application notes
Where to begin:
and type the topic.
examples to open.
