Hi.
I can't find any category for GoldenGate.
So I build a thread of GoldenGate in this RFDE category.
In RFDE, "port" and "vsource" in analogLib have instance parameters of "pacmag" or "pacdbm" which are originally for PAC and QPAC analysis of Cadence SpectreRF.
But these parameters of "pacmag" or "pacdbm" are valid even in HB small signal analysis in Spectre compatible mode of ADSsim.
So I can excecute PSS/PAC, QPSS/QPAC of SpectreRF and HBSS of ADSsim using completely same test bench schematics.
Only one difference is how to set frequency for small signal. SpectreRF setting is absolute frequency while ADSsim setting is relative(offset) frequency.
Now I'm moving to GoldenGate from RFDE since our local Agilent sales forced us to purchase high price Goldengate.
But I can't find how to execute HB SS analysis in GoldenGate. :'(
At least, it seems that "pacmag" or "pacdbm" parameters of "port" and "vsource" are not valid in GoldenGate.
What component and parameter should I use for HB SS analysis in GoldenGate ? ???
This is Nacim Bravo from Agilent EEsof here in California. I sent a direct email to your email account. Please let me know if I addressed your question fully.
You do not mentioned that circuit your are using, then you cam use the Small Signal Noise Analysis (SSNA) to compute noise and gain for small signal in a nonlinear circuit and a large signal. SSNA can be used in mixers, amplifiers. Please refer to chapter 14.1 for the configuration portion of a design for SSNA from the GoldenGate simulation User Guide.
Thank you,
