I have the next error using RFDE-Momentum simulation:
-- ERROR ---------------------------------------------------------------------
Mesher input does not contain any valid shapes. Your shapes might have been ignored because they were drawn as polylines on a strip or slot layer they were on an unmapped layer.
U2 is installed in our server and we have installed the “hotfix-20081008-rfde-momentumâ€
Please send me your full contact information. Â I need to ask a few questions.
The error message tells you that the mesher can not find any valid geometry input in order to generate meshes on it.
The mesher only looks for geometries on layers that are mapped in substrate. If you drew the geometries on certain layers and those layers were not mapped in substrate, you will get this error message.
---If the geometry drawn on a layer is polyline instead of polygon, even though the layer is mapped in substrate, the mesher will still ignore it and issue the error message because geometries on strip/slot layer have to be draw as polygons.
Please be sure sure all geometries on strip/slot layers are drawn as polygons and make sure all those layers are mapped in substrate.---
Here is my contact information:
nacim
nacimBravo          t: 707 577-2028
Applications Engineer       f: 707 577-3948
AGILENT TECHNOLOGIES Â Â Â Â Â Â e: nacim_bravo@agilent.com
EEsof/CommsEDA Â Â Â Â Â Â 1400 Fountaingrove parkway
Santa Rosa, CA 95403
______________________________________________________________
Technical Support Hotline? Â Â Â 800 473 3763
Technical Support email? Â Â Â Â Â Â Â eesof_support@agilent.com
EEsof EDA? Â Â Â Â Â Â Â Â Â Â http://www.agilent.com/find/eesof
SupportWeb? Â Â Â Â Â Â Â Â Â http://www.agilent.com/find/eesof-support
Need Training? Â Â Â Â Â Â Â Â Â Â Â Â Â Â http://www.agilent.com/find/eesofclass
