You will need to set a few environment variables before executing the comand. Please visit:
The Importing a File from the Command Line Chapter 3:3 of the Netlist Translator for SPICE and Spectre Doc in ADS. Yet, if this does not work, please send your question to our support team: eesof_support@agilent.com
error message display "ld.so.1:/nettrans:fatal:libperl .so pen failed:no such file or directory
This error indicates that, the ADS supplied shared library perl install is causing you problems. Meaning that another version of perl is being used (not the ADS shared libperl). Nettrans requires you to run the version of of perl delivered with ADS.
I hope this helps you, if you continue to have problems, feel free to send your question, and file to support.
Please try this:
$HPEESOF_DIR/bin/nettrans input_filename output_filename.net -h -g -n
nacim
