Is this the right place to post bug reports on 2007?
At the moment I prefer to use 2004 but I did try 2007 recently.
Apart from 2007 being very slow to operate and tune I did find an annoying bug.
On my PC the fonts are too small on the 2007 schematics so I have to zoom right in to read the default fonts. (1600x1200 monitor)
If I change the screen fonts then the SW locks up once I try to exit the menu screen.
The cancel button does nothing and if I press HELP the software crashes out to the "Microsoft Encountered a Problem" box.
It does this every time on my PC.
I'm not sure I know how you're changing your screen fonts to cause the lockup. What menu screen are you talking about?
In 2007 you can change the schematic fonts simply by double-clicking the schematic and picking a new font.
Also, in general 2007 is about the same speed as 2004. What application causes you to think it is 'very slow to operate?'.
 Mark
