Hallo,
My equation requires several steps with intermediate variables (2004.7 and 2007.8).
I often need to check some of these intermediate variables (debug,info,...).
Actually, the only solution I have found is to add a schematic with several resistors whose values are the ones computed for these intermediate values.
Do you have a better way to display these values,
for instance in tune window or as a static box like in Visual C in the corner of the schematic,... ?
Best regards
Best regards
Note that the leading '=' is required; it indicates that the text is an equation to be evaluated (so expressions like =Var1*Var2+7 are also valid).
