vrf Serial I/O via PC com ports
Question asked by VRFuser on Dec 8, 2000
Hi Steve,
Sounds like you don't have the Agilent (or HP) IO libraries installed.  You
should have received a CD-ROM with the IO libraries along with the VEE
software.  Install the IO libraries and run the IO config utility to
configure the COM ports.
This should do the trick.
Hope this helps,
Andy
Andy Street
Technical Consultant
Agilent Technologies
Tel: 01189-275395
Mob: 07765-897003
e-mail: andy_street@agilent.com
From: Parker, Steve T. (PS, GNF) [mailto:Steve.T.Parker@gnf.com]
Sent: 08 December 2000 16:42
To: 'vrf@lvld.agilent.com'
Subject: vrf Serial I/O via PC com ports
I am trying to use a Direct I/O object to communicate with COM1 or COM2?  I
tried and I get this error,
"Configuration Error: The SICL I/O Library, sicl32.dll, could not be found".
I assume that I just need this DLL.
Help,
Steve Parker
GNF-A
Wilmington, NC
