vrf matlab image save to file
Question asked by VRFuser on Nov 1, 2000
Richard,
If I am reading your question correctly you are wanting the filename to be a
variable defined somewhere in the VEE program (not hard-coded into the
MatLab script object). Try the following line of code for the print
statement.
print ('-djpeg', filename);
Using this syntax allows parameters to be passed into the print function
while the syntax you are using assumes the arguments are not parameters.
Hope this helps,
Lyle Carnahan
Agilent Technologies
From: Richard Kleinhenz/Fishkill/Contr/IBM [mailto:scubaman@us.ibm.com]
Sent: Wednesday, November 01, 2000 6:08 PM
To: vrf@lvld.agilent.com
Subject: vrf matlab image save to file
I am further along, but still not home.  A short version of the code is
bar(X,Y);
xlabel('V');
ylabel('freq');
title('Vbd Distribution');
print -djpeg filename;
X, Y and filename are input pins to the script object,  filename is type
text.  I don't get a file.  If instead of filename I specify explicitly 'c:
     est.jpg' it works.  I must be getting the syntax wrong.  There is no
error, just no output.
Please copy me directly on any responses, at scubaman@us.ibm.com, I am
having some trouble with my userID and subscription.
Rich
Richard Kleinhenz
tieline 8-532-2617
