When you modify label options, legend and y-axis label are changed with this label.
But, for example, you can have 3 curves for a same parameter but à 3 different temperature so the legend has to be changed but y-axis label had to be the same ( ex dB if parameter is s21 ) ...
I'm not entirely certain I understand what you would like fixed. Can you please give me a bit longer example?
Mark
