I run Eagleware on a desktop; the hardware key is connected to a DB25 printer port.
I am planning to buy a laptop as a desk-top PC replacement - it will likely not have a printer port. How can I use the same key to serve both laptop and desk-top operations?
Hardware keys are available in two styles; parallel and USB.
Please contact us support@eagleware.com and indicate the
serial number of your hardware key if you'd like to explore
replacement of your Parallel key with USB.
