Cut/Paste does not currently work in the"graph properties"
dialog box. Cut/paste would be handy when creating
equations-of-parameters to graph. I currently find myself
retyping these equations often.
Also, when cutting from a schematic and pasting into another,
the paste operation should put the circuit in the middle of
the viewable window. Currently, the paste operation usually
places the circuit out of the viewable window - so you have
to go hunting for it to see if the paste acually worked.
When you paste into a new schematic, the parts are placed with the same offsets as the original parts in the original schematic, which is the preferred placement if you are trying to duplicate an existing schematic, prior to modifying it. To easily see the newly pasted elements, just press the Z key, which zooms the schematic to include all elements.
I've been considering adding a Paste Special command, which might include an option to "paste at cursor location" or something like that.
