I have been attempting to use testlink with my HP8753E-10 to display data of a series of parts. The data that I have been accessing is a connector gated out of a cable assembly. As you can see in the attached .wsp file each time I attempt to transfer the data it is different. I am at a loss to describe what is happening. Sometimes it seeme to work perfectly and others not. I am using 1-Channel (formatted) to dowload the data to eagleware. If i use the (R,I) data the gating that I am using is disregarded. PLEASE HELP.
Merrick M. Moeller
mmoeller@cinch.com
630-693-2062
Merrick M. Moeller
mmoeller@cinch.com
630-693-2062
