I have been using the TOMN model and understand all the required parameters with the exception of the "area" parameter. I normally think of the device periphery, which is defined as , number of gate fingers x gate width. So if I have 6 gate fingers at 50microns, this will yield a gate periphery of 300microns. What is the "area" and how does it relate to the gate periphery? I do not see any dimensions, is it a relative parameter, and if so, relative to what?
Thanks
Tony
Thanks
Tony
Good Luck!
Sergey Trushin
