This is the command prompt utility so it will need to be downloaded, unzipped and a command prompt window will need to used. Make sure the folder HASP_HL_driver_cmdline_5.22 is listed using the dir command.
To install drivers for Eagleware dongle (dark purple key with a 4-5 digit serial number)
From the command prompt window:
to see what version of the driver is installed
to remove all drivers
to install 5.22 HL drivers
Once drivers have been installed, the top screen and bottom screen should match in versions using the haspdinst -info command.
Now checking the "Show My Current License Status..." window should report Driver Version: 5.22.
