Common wireless sources are now available for SPECTRASYS. The attached 'zip' file must be unzipped and all '*.src' files must be copied to the "...\\Genesys...\\Model" directory. Genesys version 2003.03 or greater should be used.
These source files were created with an Agilent signal generator and spectrum analyzer. The analyzer data was then formated into a '*.src' file.
The included modulation types are:
-Bluetooth
-CDMA2K
-CDMA2K 3 Carrier
-EDGE
-GSM
-IS95A Forward
-IS95A Reverse
-NADC
-PDC
-PHS
-WCDMA
-WCDMA 3 Carrier
[file]spectrasyssources.zip[/file]
-Bluetooth
-CDMA2K
-CDMA2K 3 Carrier
-EDGE
-GSM
-IS95A Forward
-IS95A Reverse
-NADC
-PDC
-PHS
-WCDMA
-WCDMA 3 Carrier
