Can anyone tell me in the spectrasys tool bar there is a Antenna Path module. There is a term in the properties of that module name "DISTANCE". Is that distance is in meters? Regards
The units for distance is arbitrary. However 'Lossa' is the rate of the attenuation for the same distance unit. Therefore, if the distance is in miles then 'Lossa' must be the attenuation in dB per mile.
