The LDMOS libraries are encrypted at Motorola's request. To use the LDMOS libraries in your application you must have the latest operating system version.
In particular, LDMOS requires Windows 2000 SP3. We are not aware of other operating system incompatabilities with the latest version of GENESYS.
If your operating system is not up to date, then GENESYS will produce error message 4183 when it attempts to load the LDMOS libraries at startup. The error is "Input Format Error : 80090019".
If you are running an older version of GENESYS 2003.03, then the LDMOS models may not be available on Windows 98. If this is the case, then you should download the latest GENESYS 2003.03 patch by selecting "Check Eagleware Web site for Updates" from the "Help" menu in GENESYS.
Mark Zachmann
Mark Zachmann
