Is there any way to stop Genesys from changing the mouse's motion?
When the Genesys window is active, the speed and acceleration
of the mouse gets is drastically reduced.
When Genesys is active window, I need to move the mouse 3" to
go from top to bottom of the screen instead of the 1" for all other
programs. It also appears that any motion acceleration is lost
when the Genesys window is active.
Could not find an entry in HELP for "mouse" or "cursor"
Genesys is the only program that has this issue of numerous programs
I run including several CAD/engineering programs.
Rob Lefebvre
The mouse driver was the problem.
For some reason the Logitech driver decided Genesys was a game.
The default driver setting turns off all acceleration in games.
Deselecting the "Smart Move" box in Mouse Properties/motion
fixed the problem.
Thank you for the suggestions.
SteveP
