I'm trying to use the Viewer with the Signal Control\\Dual Mode Coupler.WSP example.
I've re-simulated the FineGrid simulation with "Generate Viewer Data" enabled. But, when I try to run the EMPOWER viewer, I get the following error:
"Error locating necessary initialization files." Searching this forum suggests checking the DEFAULT.EG$ file to make sure all the paths are correct, which I have done.
I'm running the demo version of Genesys 2003.03.
Suggestions?
Suggestions?
Rob Lefebvre
