Save image
Question asked by kozlov on Apr 26, 1999
Latest reply on Apr 26, 1999 by kozlov
At 12:02 27/04/99 +0200, you wrote:
>----- Original Message -----
>From: Juan Vera <jvera@mdr.indra-espacio.es>
>To: <hpvxd_xc@hpislsup.lvld.hp.com>
>Sent: Monday, April 26, 1999 10:50 AM
>Subject: VRf: ActiveX and time-slicing
>> If an ActiveX control event handler is enabled and a defined event arises,
>> VEE always calls the involved VEE function (where the event is treated) in
>a
>> no-time-slicing fashion.
>> Does anybody know how to invoke a VEE event function in a time-slicing
>basis ?
>> Thanks in advance.
>Use a global var in your event handler which changes its state by the event.
>Then return to standard VEE and in a continous loop check the state of this
>var. If the var is set ( event occurred) then you can call the vee-function
>and it will time slice.
Ok but this approach does not take benefit of the event oriented programming.
| Juan Vera                         |
| E-mail:     jvera@mdr.indra-espacio.es     |
| Phone:     34-913 963 986               |
| Fax:          34-913 963 912               |
| Earth Stations Department               |
| INDRA ESPACIO S.A.                    |
| Mar Egeo 4, Pol. Ind. 1               |
| San Fernando de Henares               |
| 28850 MADRID                         |
| SPAIN                              |
