I tried one multi-port simulation, and totally has 6 ports. To reduce the parasitic effects, I extend the line feed voltage source to the sheet port.
After the automatic meshing, the output window pops out the following warning.
!!! WARNING !!!!!!!!!!!!!!!!!!!!!
The top and/or bottom of the distributed port 1
is only partially connected to a conducting object!
I set the six ports using the same procedures, simply have no idea why only port 1 has this warning,
anybody ever encounted similar warnings?
Your help is really appreciated!
