I'm new in the area of ADS and Verilog-A and have some Problems.
I should convert ADS FET transistor models, which consists of an SDD, a Current Controlled Votage Source and some resistors, into a Verilog-A model.
The Verilog-A model should be used in ADS as replacement of the old model.
I've read the manual from agilent for converting an SDD into Verilog and I've done the tutorial. But for my model I must made a mistake.
Now I have some errors, since I added one parameter to an resistor. This is my first question.
The simulator reportet these errors:
Error detected by hpeesofsim in Compiling Verilog-A based device.
Warning: Ordered parameter lists are only supported for Verilog modules.
['/hpusers/aschlege/Verilog-A/test_prj/data/../veriloga/TLS_va.va',75]
Error: Invalid (non-static) initialization for parameter 'R'.
['/hpusers/aschlege/Verilog-A/test_prj/data/../veriloga/TLS_va.va',73]
Peace of code:
module TLS_va(g,d,s);
parameter real UGW = 30;
//Dummy Wiederstände in Ohm
real R_dummy1 = 1;
real R_dummy2 = 1;
/*Bauteile*/
Resistor #(.name("r_dummy1"),.R(R_dummy1)) r_dummy1(sdd3,gnd); //line73
Resistor #(.name("r_dummy2"),.R(R_dummy2)) r_dummy2(sdd5,gnd);
Resistor #("R_d", R_d, 1) r_drain(d,iccvs); //line75
Resistor #("R_g", R_g, 1) r_gate(g,sdd1); Resistor #("R_s", R_s, 1) r_source(gd,s);
CCVS_VA ccvs(iccvs,sdd2,gnd,sdd4);
analog begin
WF=UGW/1000;
WZ=WF/2;
Wtot=WF;
R_g=rg*WZ;
R_d=Rb/WF;
R_s=Rb/WF;
end
endmodule
The values for the resistors will be calculated after declaring the resistors, can this lead to this error?
But why occurs this error first after inserting the first parameter "name" for the resistors?
I search also a good book about Verilog-A. It should habe also examples for better learning and understanding.
Can someone help me to solve my problem and/or recommend me a good book?
Thanks
iafmember
Peace of code:
real R_dummy1 = 1;
real R_dummy2 = 1;
/*Bauteile*/
analog begin
WF=UGW/1000;
WZ=WF/2;
Wtot=WF;
R_g=rg*WZ;
R_d=Rb/WF;
R_s=Rb/WF;
end
endmodule
Thanks
iafmember
