Hi All,
I'm having problems trying to specify a large number of carriers using the P_SpectrumDataset signal source.
The first thing I did was to create a txt file of may data (reduced to just 10 for this example)
BEGIN DSCRDATA
% INDEX mag ang
2 -109 0
3 -122 0
4 -117 0
5 -112 0
6 -108 0
7 -105 0
8 -105 0
9 -104 0
10 -102 0
END DSCRDATA
I then read it using dftool, format MDIF, Discrete and specified the data set file. When I read the dataset I get
Independent Variables:
Name Type
INDEX String
Dependent Variables:
Name Type
mag Real
ang Real
Which I assume shows that the dataset has been correctly generated. In the P_SpectrumData expression I have specified "polar(dbmtow(mag),ang)". When I run harmonic balance (just looking at the output of the source, I get a dsexpr: Expression (polar(dbmtow(mag),ang)) failed to evaluate error??
Any suggestions or examples of how I can get this to work?
Cheers
John
BEGIN DSCRDATA
% INDEX mag ang
2 -109 0
3 -122 0
4 -117 0
5 -112 0
6 -108 0
7 -105 0
8 -105 0
9 -104 0
10 -102 0
END DSCRDATA
Name Type
INDEX String
Name Type
mag Real
ang Real
Cheers
John
