Hi All,
I would like to find a way to convert an RFDE substrate definition in *.tch file format into ADS Momentum
Is there a special script to do this?
Kind regards
Marino
Kind regards
Marino
You can download the utility design kit from EEsof Knowledge center.
http://edocs.soco.agilent.com/display/eesofkc/Home
Enter "tch lay" as keyword for search and you'll see "momentum data transfer between ads virtuoso" as a result.
I hope this helps you.
Regards
Satoshi
