Hi
I am struggling to model some vias through split substrates. I need some vias going through all the substrate layers and some through just one substrate. I use 'polyline' in the 'hole' layer to model it. But the problem is when I map holes to all substrates to achieve the former then latter condition cannot be achieved.
please let me know a way around this.
Thanks
Ruwan
Thanks
Ruwan
Then, use/create another layout layer for a via that needs to got through just a single layer. For instance, add a new layer called "hole2". Then map that layer to go through the desired subtrate layer in the substrate setup.
Anything you now draw on the "hole" layer will be considered as a via through all substrate layers. Anything you draw on the "hole1" layer will only be considered as going through that one layer.
If you need other vias that goes through another layer(s) - just add new layer(s) and map them accordingly in the substrate setup.
-Mats
