Hi All,
I've set up different filter simulations (microstrip technology) in different projects. The values to be changed are among other things the substrate thickness, dielectric constant and loss tangent in the substrate definition located at the schematics window.
Is it possible to access these values in the display window in order to display them for demonstration purposes. How can this be accomplished?
Any help in this matter is much appreciated.
Ralf
Ralf
I'm not sure if I got your question correct, but if so I would solve the problem as follows:
Define the substrate parameters as variables (I guess you have done this anyway...)
Take care that your simulation engine writes this variables to the output file ("output" tab in the simulation engine)
Now you can access all variables in the Data Display ..
regards
hermann
