Hi.
I wanted to simulation the Spiral Inductor S-parameters and computed far_field.
1.Set top freespace-FR4-freespace ;
2.set cond as 1st strip,hole as via,cond2 as 2nd strip;
3.set S-parameters simulation;
4.Port 1-port2 set in cond,port3 set in cond2;
faild"
The Circuit Source number "1" passes through a metal object
>>>>>>>>> over the portion of the path from
>>>>>>>>> (775, 150, -175) to (775, 150, 25).
>>>>>>>>> Circuit sources may not exist in or pass through
>>>>>>>>> metal objects.
>>>>>>>>> Please redefine Circuit Source number "1".
attachment my prj
faild"
>>>>>>>>> metal objects.
attachment my prj
