In ADS data display, I've got data that is function of both freq and bias (ie data[freq,bias]). At each bias point, I want to subtract the data at freq=0 from the rest of the freq points.
ie dataNew=data-data[::,0]
But data[::,0] has different dimensions to data[::,::] so this gives an error. Is it possible to create a new array that copies the data at freq=0 to all the other frequencies at each bias, so the above subtraction can be carried out?
Thanks for any help.
dataNew=data-expand(data[::,0])
By the way, your data probably has the structure [bias,freq] and not [freq,bias].
