I´ve just installed the new 2008 version of ADS.
The new "look & feel" is very nice, but some operations have become slower than with the old 2006 version.
Especially in the data display window, when I place a new chart it takes around a second until the window with the selection of the available curves pops up. In 2006 there was no noticeable delay as it is now.
In the schematic and layout window the new panning-function with the mouse right-clicked causes a quite slow screen refresh.
Does anybody else have the same problems?
Is it possible to turn off the right-click panning-function?
Best regards,
Thomas
Best regards,
Thomas
I also noticed the same problem and just contacted the Italian Support.
It seems that it is related to a different way that 2008 uses to send the images to the X server. If you want I can paste the response I got from him (it is in english so it should be fine). However, it seems that a solution will be available with the first update.
Ciao
Francesco
