Hi!I have some problems about port type in co-simulation.
1.I drawn PCB all with rectangle in layout,I don't know how to add nodes in PCB in order to connectting FET or resistor in schematic page for co-simulation?
2.I have added some ports(internal and single)to my PCB and can connectting with components in schematic page
,But whatever port(internal) or port(single) both are 50ohm impedance,so if a 100ohm resistor connect after the port,Seeing from port will be 150ohm?
Thanks!
-cqcq
Thanks!
-cqcq
parameter will reflect the effect of that.
