i measured 60 sparamter files for 60 channels
Now what i want to do is that i want to do 60 simulation sweeps and want to calculate BER.
i want that after each sweep i can change s parameter file in S block and calcualte BER. and also after every sweep i want to change fingerdelay in UWB finger correlator.
Using DAC
is it possible?
if not can anyone sort out the problem
problem can be divided in two parts
1. for a 1 s parameter file i want to sweep finger delay 60 times
2.if this work then i ll synchronize s parameter files and finger delay file
but in my 1st step i m getting error u cant modify N of uwb finger delay.
Using DAC
is it possible?
An FIR filter with taps "0[N] 1" (this syntax means N zeros followed by one 1) is effectively a delay of N samples. You will have to create the string "0[N] 1" using sprintf function.
Please do not create a new topic if you want to respond to this one.
