I am doing a SP simulation of a simple noisy circuit containing a noisy resistor. I would like to change the temperature of the resistor at each frequency point - ideally Temp=300+freq/1G or equivalent expression. Is it possible to do that? If not, is there a workaround? It looks like the resistor's Temp parameter cannot change over frequency...
Luciano
Luciano
best regards Henry
