I want to simulate a combline filter using ADS. I've calculated its physical dimensions, that is, the dimensions of the resonator bars. I would like to know how to insert these dimensions in ADS for the simulation and to produce a layout? Must I insert the dimensions when creating a substrate?
Thanks.
Thanks.
Since you mentioned 'resonator bars' it sounds like you are designing a combline in a cavity. I don't know that ADS can simulate it, since ADS is a circuit simulator and uses models for mostly printed circuit media, lumped elements, etc. I would think you need a 3D electromagnetic simulator like EMpro or Ansys HFSS.
