Hi, several times in the past I had the problem, that I had some time domain signals in a .ds file but I wanted to have it in anohter .ds file (e. g. to have only this trace in the file removing all the other information out of the .ds).
The only (more or less practicable) way I found was to export the signal to ASCII, add the header for an mdif file and import it into a new dataset ... this is quite inconvenient and does not allow to combine two signals in a new .ds. Additionally the last ASCII file I had was 100MB and most text editors does not really like this file size .
Does anybody know a simpler way to transfer information between .ds files ????
thanks and regards
Hermann
thanks and regards
Hermann
