Q. Does anyone know if there is a way to suppress the output of the time variable (& TranOrder) to the dataset following a Transient simulation?
Background: I'm running a transient simulation of significant length, sweeping several parameters, and calculating a spectrum of a particular voltage node using fs in a Meas component. In fact, I'm only sending an isolated portion of the calculated spectrum to the dataset. Unfortunately, due to the length of the simulations and the depth of the sweep, the time variable (& TranOrder) that is sent to the dataset results in excessively large datasets.
Thanks
Thanks
Very interesting question though. Has me thoroughly stumped!
Thanks
Nilesh 8)
