Hi to all,
I like to build a nonlinear behavioural amplifier model for OFDM signals. I understand that there is a similar behavioural "Amplifier2" block under the Analog environment:
http://edasupportweb.soco.agilent.com/d ... ys017.html.
In Table 2, the polynomial order for various magnitue orders are shown.
I have a few questions:
1. Does it make sense to set the Magnitude mode to TOI, GainComp = 1dB, GainCompPower for a behvaioural amplifier for OFDM signals, since TOI is obtained by a two tone test, while OFDM is a multi carrier signal?
2. If the above mentioned magnitude mode can be applied, how can I extract the coefficients for the third order term and the fifth order term?
3. Are there any good references for such RF amplifier behavioural modeling?
Thanks!
Thanks!
