I have a certain requirement for my work.
-> Simulate large number of different circuit toplogies.
-> Each topology has a certain response it should match, thus I use goals and optimizations in my circuit.
I have done the above design steps manually in the ADS schematic window. I need to automate the entire process as large number of different circuits need to be optimized.
What should I use ?
-> AEL? How do I generate different netlist using AEL... note my netlist needs to have optimization goals.
-> How can I import a design use ADS netlist file format... ?
I am new to ADS and any help would be appreciated.
What should I use ?
A quick search in the documentation can give you more info on the above 2 items.
nilesh
