I want to use the Variable Equation command to differentiat a voltage at point in time domain. Please let me know how to do that as soon as possible.
Yours
Sohaib
Yours
Sohaib
Created an s variable (s=j*2*pi*freq) using in a VAr block. Place a VCVS (voltage controlled voltage source) on the schematic and make the gain equal to s(G=s on the VCVS, leave other values at default). Connect the input side to the voltage you wish to differentiate. The output of the VCVS will be the differentiator output.
